mike brez wrote:
Were going away in a few weeks and want to change both. I need about four feet of snow to melt to get rv out and once out I won't be able to get it back to its parking spot due to soggy grass. Do you think with engine running at high idle for 20-30 min would heat oil up enough? What about tranny would draining and re filling cold be sufficient.
Drain oil asap with a new filter cold. Check fuel filters also.
Let tranny go until late spring or summer and do it all with both filters, etc, etc. Go with Transynd then!!
Check coolant level...grease slack adjusters on the air brakes and give the driveshaft a hit of grease.
Your ready to roll then
