chuckftboy
Jul 20, 2015Explorer
You do not need a shroud, once you are moving the fan probably turns off on temperature anyway. Electric fans are normally used for when you idle or are moving slow in traffic on a hot day, thermostatically controlled. It is possible to cool a condenser too much, not creating enough high side pressure to properly feed the TXV or metering device there by reducing capacity.
Unless you travel everywhere at 20 MPH or less its probably good the way it is.
38,782 PostsLatest Activity: Sep 10, 2026
