mtrumpet
Jul 10, 2015Explorer
Executive wrote:
Mark, I don't think anyone said any of the brands suggested were unsafe. Michelin and Goodyear are the only two brands formulated specifically for RV use. That means they contain compounds that help reduce the UV damage to tires from non use. I'm not a tire engineer, but I did stay at a Holiday Inn once, so I can only rely on their printed assurances. These compounds also provide a softer sidewall which results in a softer, (smoother) ride many RVrs are demanding. Yokohama, Hankook, Toyo etc. are all truck tires and are designed to provide a longer tread life that truckers demand. RVrs do not. Because of these factors, those tires are harder and more substantial than the Ms or GYs making the ride more pronounced. IMO, they are all safe tires and your choice should be dependent on your requirements. The softer, smoother ride will cost you a little more....Is a Mercedes safer than a Chevy..? Nope, but the MBZ sure costs more.....Dennis
:B:B
38,782 PostsLatest Activity: Aug 11, 2021
