dad2aprincess's avatar
Jan 17, 2015
OK to run furnace while traveling?
Do you all run your gas furnace while traveling down the road? Is there any problem with doing so? The electric heat is loud and doesn't work very well when it is this cold.
  • If it is real cold where the dash heater can not keep you warm, there is nothing wrong with running the furnace. I have done it before when traveling through real cold weather.
    Or if your coach is equipped with heat pumps, you can also run the generator and turn both heat pumps to warm up the coach.
