Bordercollie
Jul 14, 2021Explorer
My little 2-gallon Campbell Hausfeld 120vac compressor was able to pump 75psi into RV tire.
Tips for small compressors: It runs as long as needed to get to 100psi in the tank then it shuts off. You have to jamb the chuck quickly onto the tire valve, so as not to lose any air, listen carefully as air goes slowly into the tire, then check psi with accurate gage, without losing air. May need to repeat until you "sneak" in enough air to reach 75-80 psi.
