turbojimmy
Aug 20, 2017Explorer
I finished the left side. The right side is the old halogens. Once it gets dark I'm going to do a side-by-side comparison. Yes it's dirty - it's been sitting in that spot under the trees since June.
I got greedy and tapped into the low beam circuit for the bottom lamp. Normally that one is not lit up when low beam is selected. But...since these lamps are both high and low, I figured 2 low beam lights on each side can't hurt. They draw a lot less juice than the halogens so it should be fine. Low beam just lights that top row of LEDs and the one in the middle. High beam lights them all up. They're DOT approved, too.
