joe_b_
Sep 14, 2014Explorer II
We had an early 80s model Mobil Traveler (MT) with a 350 Chevy engine in it. As I remember it was about 25 ft in length with bunk beds. We had two young daughters at the time so the house layout was great. However, even though it was and probably still is our favorite RV we have ever owned, it was a maintenance nightmare.
The seller, shall we say was less than honest. He was an Alaskan snowbird that wintered in Arizona and summered in Fairbanks. He would fly outside to Arizona, buy a used RV, live in it for the winter and drive it back to Fairbanks the next summer. Told me he had done this for a number of years. When I asked him if it used any oil on the trip up, he told me, some like most RVs do. Yeah, the first time I checked oil consumption it was a quart per 100 miles. Rather than buy oil by the 5 gallon buckets I had it checked out and found 3 of the 8 cylinders had cracks in the heads. So the first head change occurred in the fist few months of ownership.
The engine in our rig did not have good cooling for either the engine or the accessories mounted on the engine. We had to replace the alternator three times, the power steering pump, etc. but the big cost item was having to replace the heads (3) three different times. The rig had just over 20K miles on it when we purchased and finally got it to over 100K when we traded it in. Either the front clip had to be removed or the engine dropped down out of the frame to be able to change out the heads. The labor cost was very high but it wasn't a job I wanted to take on. We had to replace the Quadrajet carburetor once at a cost of over $650, back then. The heads were cracking between the valves and we were lucky a chunk of head metal didn't drop down in the piston hole while the engine was running. also had to have the transmission rebuilt twice, had to replace the furnace, the AC roof unit and the fridge. The fridge was obviously put in place prior to the roof being added so the dealer had to remove the passenger seat and front door to get the ole one out and new one in.
Plus the floor and the dog house got too hot to even have your feet on the floor when driving in warmer weather. I had to build an elevated insulated platform on the passenger side for my wife to put her feet. Never did solve the heat transfer problem.
The rig we had used a 4KW Generac and the low hours on it when we purchased it was a factor we liked. However after a few years of dealing with that generator, I could see why it was low hours as I wasn't able to keep it running any better than the first owner. LOL It was still under 200 hours when the odometer on the RV rolled over the 100K figure. Basically if there was a part on that MT that moved, I had to replace it, sometimes once and sometimes multiple times during the 80K miles we put on it.
Take a look at how you plan to use any older RV. If a 100 mile trip to the lake or favorite campground a dozen times in a summer is about it, then older ones are often a good buy. But if you plan to put lots of miles and nights on/in the RV, a newrer one, even if high mileage may be a better buy in the long run.
The memories we have of the old MT are great, as we made 6 round trips to/from Alaska to the lower 48 with it and I knew where some of the best and worst Chevy repair shops in the country, were located. LOL If the owner is a good handyman or woman, then the older ones can be a good hobby as well. But if you have to hire most of the repair work done at a shop, probably not a good buy for most people. My wife told me one time she thought we had probably spent $4,000 or more a year, for maintenance, on the MT the years we owned it and I suspect her figure, of costs, is low, but the family enjoyed the rig and the trips.
The odd size of wheel is also a problem and was becomming such by the time we got rid of the MT. Just a few shops stock a tire to fit a 16.5 in wheel, and the ones they still make are about double in cost and often have to be special ordered. So if the old rig still has the 16.5 inch wheels on it, be ready to spend about $2,000 to replace then with an appropriate sized 16 inch tire and wheel.
38,778 PostsLatest Activity: Jun 06, 2026
