jeeperdude10's avatar
jeeperdude10
On Board LP gauge
Since my last LP fill up my on board level gauge shows 1/4 constantly, but the actual digital gauge on tank shows just over 1/2....it is apparently working as it showed 3/4 when filled. If I undo the leads and reattach, the on board gauge goes through the whole thing F 3/4 1/2 and settles at 1/4. Has this happened to anyone else? What may this possibly be? Just boggles my mind that this is happening. Our coach is a 16 Bounder 35K, and have not had any issue with this whatsoever...time since fillup is close to 6 months now....just hoping as level goes down it might "catch up".....
  • I have our SeeLevel tank monitor calibrated so the full (80%) LP tank reads as 100%. Since I only want to know how much liquid is left, that works for me...
  • Ive filled thousands of tanks and bottles. This is common that the remote does not match the actual float level guage. Trust the float. Now, what about that 1/4- 3/4 thing?
    If 80% just a smidge over 75% is full, then shouldnt the guage show 1/3, 2/3, full?
    know your tank size. The WC # on it is a weight of LPG if its portable is its capacity of water, so 80% is its capacity in LPG.
    On mounted asme tanks, capacity is given in gallons, also in water capacity, so 80% of the gallons capacity in water is the LPG capacity. A common C Mh has 40# tank. about 10 gallons. At 1/4 on the guage, you still have 1/3, or 3,3 gallons.
  • The sender is a 0-90 ohm rheostat. You should be able to pop it off the tank and take some readings. That will tell you if the sender or gauge is bad.
    Richard
  • Ours inside no longer matches what the tank says either. We just go by the tank.
  • Sounds like the sender is getting flaky. Mine is broken and someone replaced the gauge with a regular one. I found the electrical sender for $55 on Amazon it just snaps on where the existing one is. Very easy to replace.
