cavie
Nov 22, 2019Explorer
No fuses under the hood. Your coach works off House batteries. Lights, range hood are 12 volts. Furnace is 12 volts. WH has 12 volt control circuit. Fuses will be on the converter. You don't look at them to check. You use a multi-meter and confirm they are good. Is the converter turned ON? Is battery disconnect switch ON? Battery fully charged?
