MrWizard
Nov 22, 2019Moderator
I have a 97 Bounder on the F53 chassis
Fuse number '5' marked appliances , supplies the range hood, water pump, water heater, etc..
Mine are numbered from right to left
#1 far right, number #12 not used is far left
Yeah backwards from normal
Fuse circuit board looks like it was supposed to be used as vertical mount, top to bottom, but has been turned / mounted 90° clockwise
Try new fuse in #5
Otherwise time to open up the range hood to get at the wiring
I see you found the problem
You posted while I was typing my post
Enjoy your trip
Try new fuse in #5
Enjoy your trip
