Idle-Up
Sep 20, 2021Explorer
Reisender wrote:Idle-Up wrote:
Thanks for all the replies Regretfully, Bruce it looks like it's impossible to get a few members to believe they don't own an inverter generator. All they need to do is start their generator up and listen to it race without a load, nothing like the new 6-8 kw diesel Kubota engines at idle most all the time.
Stay Safe - Mike
Mike. Our 2003 7.5 Onan quiet diesel was an inverter generator. Starts quiet. If you turn on a load it speeds up. Turn on another load it speeds up more etc. I think you may be confusing older Onan gas generators with diesel generators.
Cheers.
Thanks for the reply - Your 2003 is not an inverter diesel generator.
The changes your hearing is not that of an inverter generator, what you’re hearing and mistaking for a faster speeds is actually the engine speeding up momentary from a drop in rpm from as load was applied. In addition, it only sounds like it’s running faster but it's just additional “mechanical” noise from the Kubota diesel engine working harder with the load. Once the load is gone, the engine gets quieter (appears to be turning slower) but only because it’s no longer working and relaxed with less diesel mechanical noise.
The newer inverter diesel generators idle down so low you can barely hear them running. There is a no comparison to the older generators. believe me I've been doing this since 1978 and owned over 20 diesel Onan's since then. The first Inverter generator I owned was in my 2020 Renegade. As soon as I heard this difference in operation, I called Cummins / Onan and they confirmed it was a Inverter generator.
I also mentioned this same Inverter generator in more detail in my In Depth article which I authored you can find it at:
Renegade In-Depth Review
Regards - Mike
38,782 PostsLatest Activity: Sep 02, 2026
