Jim_Carolyn's avatar
Jim_Carolyn
Onan 2800 Generator
I've had 4 people look at my generator and now I'm tired of messing with it. I want to replace it but don't want to pay the $2500 that Cummins/Onan wants for a new one. Anyone know where I might be able to obtain a used/rebuilt one? Or does anyone know of a reliable tech that repairs these?
  • Jim,
    While I can only aspire to one day be as "wrench savvy" as Handbasket, here's my $.02.
    In my limited experience, the Onan 2800 is a reliable device - provided one does as one should with respect to maintaining it. And, having read your posts for quite a while, I suspect you do so.
    The 2800 IS very fussy about oil levels - and they say so in their manual. (I used to think it wasn't there, but I was corrected on that point). That's really easy to check. And, the recommended 2800 oil level is different that every other Onan genset. Some "new" techs don't know that - yet.
    If you're going to go see an Onan service facility, you might think about the http://www.cumminspowerclub.com/. Their $15 (as I recall) annual membership is good for a 10% discount on anything and everything "Onan" you get from or have Cummins/Onan do to/for your genset.
    Finally, were it me, I'd take Handbasket up on his offer in an instant.
    Cheers.
  • Jim, Beyond eBay & CraigsList, the only thing I can suggest for a used one is to call or send an email to the service department managers of various RV dealers in your area.
    As far as a good tech goes, I used the then-new Cummins-Onan distributor/service center in Spartanburg SC when the Tiger's 2800 failed under warranty in 2006. I can't really recommend that route. I had to return to have a vital bolt in the governor linkage tightened about a month later. The original tech was no longer there. Years later when replacing the fuel pump, I found that he had also left out a vibration isolator the 1st time. They mailed it to me free, with no more proof than a phone call & an emailed photo. It didn't really change the noise & vibration, but it still left me with a bad taste.
    I'll be glad to help you troubleshoot it if you want to try. There are 3 pretty simple things that are common failure points. None cost over $250-300 and a half-day of DIY work, tho' you do need to drop the box to get to at least one of them.
    Jim, "Blessed is the end user who expects nothing, for he shall not be disappointed."
