Jerry_Amerson1
Sep 28, 2015Explorer
I finished putting the new fuel pump, fuel filter and air filter in this weekend and mounted the pump and filter on the outside of the sound wall so they will be very easy to change in the future.
I also got the Chemtrol B12 and mixed 2oz with a fresh gallon of gas. When I started it up I had the same problem, need to choke it to keep it running. If I don't hold the choke almost closed the unit surges and the governor tries to keep it running but it finally dies. This is with no load at all on the unit, and it only runs for a minute or so.
I'm thinking about taking the bowl off the carb to clean it out but I don't see an easy way of doing that. Does anyone have any suggestions as to how to safely do that. There is a nut on the very bottom of the carb that looks like what will loosen the bowl.
If anyone has any other suggestions I'm open to them.
Thanks for your help
Jake
Jake
38,782 PostsLatest Activity: Sep 10, 2026
