jdc1 wrote:
eHoefler wrote:
Pull the spark plug and try to crank it. Your fuel pump may be too high in pressure and overrun the float in the carburetor, causing it to flood out and fill the cylinder with gas and hydro-locking it.
You need a low pressure fuel pump. 2.5 to 4 psi. Most auto parts carry them for less than $30
That's what the little Edelbrock /Mr. Gasket pumps are. Although they are on the high side IIRC at 4psi maybe a bit more although likely lower if not installed in an ideal location.
OP gotta give more breadcrumbs though or the diagnosis suggestions will be random.
