bounder39zman
Apr 08, 2017Explorer II
Since you have a 5.5BGM (older style Marquis set), adjusting valve lash is a bit trickier. You will need to remove intake and exhaust manifolds, then tappet chamber cover plates to access tappets. Valve lash is .005" intake and .013"ehhaust. You will need 2 intake manifold gaskets and 2 exhaust manifold gaskets, plus 2 or 3 tappet chamber gaskets. The valve lash is adjusted at the tappets on this "flathead" style engine. Your ticking noise is possibly caused by excessive valve lash, could also be excessive carbon build up in combustion chambers, in which case you will need to remove cylinder heads and clean carbon from heads and pistons. Sometimes a can of Sea-Foam aerosol sprayed into carb can remove some carbon, but is only temporary fix. Good luck
38,782 PostsLatest Activity: Aug 30, 2026
