MikeDavies
Mar 25, 2014Explorer
othertonka wrote:
I had the same problem with the original filer leaking and did the same repair you describe using the adapter at the CARB. And it has worked for me.
Here is a link to the adapter that takes the place of the original filter
Onan adapter
Hi,
Yes I always have to prime it to start it. I pulled the fuel line from the carb to check to pump, plenty of gas. Checked the float bowl drain, plenty of gas there. I'm thinking that changing the filters kicked up some gunk and plugged up the carb. You will find plenty of posts on that problem with the Onan.
Take Care
38,777 PostsLatest Activity: May 24, 2026
