superk
Nov 03, 2014Explorer
rgatijnet1 wrote:
Reset the output breakers on your generator. The 2 VAC that you are reading does not mean that there is an actual contact.
Usually the generator circuit breakers are right at the output on the generator itself.
Thanks for the advice! I wish it were that simple. Resetting the breakers was the first thing I tried. The voltage I measured was on the hot wire going to the breaker from the generator itself, and again at the transfer switch. the genset is definitely running 2.0vac.
38,776 PostsLatest Activity: May 14, 2026
