superk
Nov 03, 2014Explorer
I tested the voltage at the brushes... from what I understand one brush is supposed to be a +12v (or more depending on needed field strength) and the ohter is supposed to be grounded?
for some reason they were both showing +5vdc.
Also, when testing the resistance between the rings and the ground, I am supposed to find one mega ohm? I found no resistance whatsoever, and when tested for conductivity, there was none. its like there was no pathway whatsoever to ground from the rings.
