bounder39zman
Jan 23, 2016Explorer II
Since you have "spark", and unit is spinning over normally, problem most likely fuel related. Most problems with LP fuel systems are with regulator vent hose being plugged up....bugs, mainly wasps, like the smell of the "perfume" of LP, they build nests in hose and plug it up, then the diaphragm of regulator will not work freely and let fuel into unit. Another possibility is fuel lock-off valve not opening and letting fuel to set, which could be a bad valve or control board. These things may help you find problem, but if you are not comfortable working with LP gas components, better to get a "pro" to check it out.
