Gdlow
Aug 06, 2020Explorer
Thanks for the info...I will copy and save it...Here is the sequence of events...Generator ran fine during trip to the campground, Started and ran fine that nite for several hours, next day ran fine for an hour or so and shut down (no Code). Started up again and ran for another hour or so and shut down (code 47) didn't need it rest of nite. 3rd nite started up fine and ran for couple of hours then shut down (no code). Started up again and ran for hour or so and shutdown (error code 47) Tried starting and wouldn't start (no code).
Next day before leaving it started fine and ran for hour or so, then I shut it down. Packed up and MH wouldn't start so had to use the boost power to start, then started generator up (while engine is running and it ran fine on 3 hour trip home...Replace Chassis battery yesterday, and had appt. to have generator checked for end of August, but had it done last Sept and had only used once before this trip...Want to save some money if the chassis battery MAY BE the issue.
