wildmanbaker
Nov 20, 2019Explorer
Russ, your problem may be the fuel line from the tank to the gen. Get some fuel line the right size, and connect it to the inlet of the fuel pump. Then insert the other end in a container of gas of know quality, and start the generator to see if it will run. If it does, the fuel line from the tank to the metal line under the MH may have dried out and cracked, allowing air to enter the line causing the problems. It is possible to change the hose without dropping the tank, if you are not too muscled up.
Good luck
Good luck
38,778 PostsLatest Activity: Jun 10, 2026
