et2
Sep 12, 2015Explorer
Refer to Table 3 for scheduled maintenance. The engine cooling system is filled with a 50/50 mixture of ethylene glycol anti-freeze and water when the genset leaves the factory, which is suitable for tem- peratures down to -34? F (-37? C).
Replace the coolant every two years. Use ethylene or propylene glycol anti-freeze solution that con- tains a rust and corrosion inhibitor. The anti-freeze should not contain a stop-leak additive.
The water used for engine coolant should be clean, low in minerals, and free of corrosive chemicals. Use distilled water if available. The cooling system has a 4.2 quart (4 l) capacity.
38,776 PostsLatest Activity: May 15, 2026
