smlranger
Jun 08, 2016Explorer
Its your call. I know some folks talk about going many more hours without doing anything other than fluids and filters.
I had a 2002 Journey with the 7.5KW Onan diesel generator. At 10 years of age and about 1,200 hours, I decided to do the full service. I used a motorcycle jack to drop the generator out from under the coach. It was not that hard to do.
I replaced all the hoses, had the radiator cleaned and checked, changed thermostat, drive belt, temp sensor and did a valve adjustment. I believe in preventative maintenance.
If you have to pay a shop to do it all, it will be expensive. However, if you get another 8 - 10 years of use before having to do it again, that may cost you less than what you would spend modifying your coach.
