Bordercollie
Jul 22, 2016Explorer
There may be a corroded ground connection from generator to frame. It could be a bad remote start switch/relay in the power panel. Could be a corroded ground connection from house battery to frame. Clean and tighten battery clamp connectors. Try starting the generator using the switch on the generator itself with truck engine running. If the house battery is old with sulphated plates it may show over 13 volts but voltage may drop way down when cranking the generator. Your house battery should be tested under load. Often a new deep cycle RV battery and clean tight connections make all the difference.
38,780 PostsLatest Activity: Jul 04, 2015
