Droptop351
Jul 22, 2016Explorer
Had this exact problem this week. All of the answers above could be correct, low voltage, bad solenoid or starter, bad cable connections.
Mine was stupid thing turned off on compression stroke so I took a 9/16 wrench and turned flywheel and loosened it up. Started right up
If you want to rule this out take the spark plug out and hit the start button if it don't turn over and just clicks then it's one of the 3 listed above
38,780 PostsLatest Activity: Mar 30, 2014
