So here is the information CA Traveler was looking for.
I used a Snap-on analyzer specifically designed to measure amperage while a starter is operating.
As shown in the picture below, my generator (Onan 10 KW QuietDeisel) has a dedicated battery that is only used to start the generator.
- The 12V+ lead is 4/0 wire 72" long. The ground wire is 48" connected to the frame.
- At the start of the test, the battery was fully charged @ 12.7 Volts.
- Outside temperature was 15 C.
- During the prestart step the generator drew 6.0 Amps, with very little voltage drop off.
- When the starter cranked, the amps peaked at 207 Amps, then settled at 197 Amps until the generator fired.
- The battery supply voltage (at the terminals) dropped from 12.6 Volts to 10.8 Volts.
- Immediately after starting, the battery recovered to 12.3 Volts.
As you may have guessed, I am a proponent of using a dedicated battery for the generator. As per a previous post, I found that even when I cleaned all my terminals from the house batteries to the generator, the generator just did not start reliably. After installing the dedicated battery, I have never had a problem. IMO...
- Due to the high current draw, 30 - 40 feet of 4/0 cable just has too much voltage loss.
- The house batteries are deep cycle batteries. Therefore, they are not designed to supply the 200 Amps necessary without pulling down the battery voltage significantly.
- When you really need to start the generator (i.e. In the morning when you house batteries are at 50% - 12.0V --or-- during cold weather) that is also the time when you have the lowest voltage available and cannot handle further voltage drop as the starter cranks.
