lamoz wrote:
It's running :)
cleaned the fuel pump, jumped the solenoid and got it to run. The switch does not crack it and does not will not stop the generator either. I have to remove the #2 fuse to kill it. I removed the connector for the remote switch from inside the RV
now the question is, could it be wired wrong? I know the fuel pump should not be running unless the generator is on. I have a wiring diagram for the generator but i have no idea how to read it.
If you could give us the model and serial numbers, it would help.
