willald
May 11, 2015Explorer II
blawless wrote:
Could be as simple as while driving down the road you let your fuel gauge go below 1/4 tank. The geneator fuel inlet will not suck gas below a 1/4 tank as a safety feature. If between 1/4 and 1/2 and you were going up hill or down hill on a long grade it will also be below the genny inlet tube in the gas tank and cause the same problem.
I'm betting this is the cause. Original poster said that this happened when they took their first real long trip with it, so I bet they got down close to or below 1/4 of a tank of fuel, resulting in the generator running dry on fuel.
I know why they are built that way, but I still don't like the fact that generator can only run on first 3/4 of a tank of fuel. When traveling in hot weather where you need your generator and air conditioners running, it severely limits your range between fill-ups when you lose your generator and air conditioners at 1/4 of a tank. I've thought a few times about trying to change this, and make the generator fuel pickup feed from ENTIRE fuel tank, not just the first 3/4 (anyone ever done that?)
Glad someone looked up the trouble code involved here, 36, which it turns out is a fuel related issue, not overheating. Does not appear overheating had anything to do with what happened here. Also, is kinda funny how folks with diesel generators swear that these Onan generators are water-cooled, since theirs is. Onan GAS powered RV generators have almost ALWAYS been air cooled, and still are. :)
