Buster52
Jul 10, 2014Explorer
Onan Generator most likely problems
I have been working on my new/used Southwind. The coach is a mystery to me. The rig is very dusty and show a lot of rust and corrosion too. Working on the generator it too is very dusty through out like it was a very dry climate. But the slip rings was corrosion heavy, along with some of the connection. Now I find the voltage regulator connection shows a lot of corrosion and may need replacing. As I was looking up the replacement voltage regulator, I noticed a statement that it is the most replaced part do it failure. But when I was looking at the control board it too was the most replace part. Other sites say the slip rings are the most trouble some part. So what is the real most trouble some part? Also I found the generator had several places were silicone was heavily applied. The connector of the brushes and the voltage regulator connection(didn't help). Does this generator have a on going problem? Or is this a problem with other generators?
