CarlGeo's avatar
CarlGeo
Onan Generator Repair
Does anyone know a good Onan generator repair technician in southern part of San Joaquin Valley California?
My generator starts, but will not continue to run.
Thanks
CarlGeo
  • Cummins locations repairs Onan generators. Cummins in Fresno or Cummins Coach Care in Bakersfield. Cummins Coach Care: www.funroads.com
    or locate Cummins service on www.cummins.com
    we found their service to be fast and reasonable prices.
  • Our Onan did the same thing - it was a filthy air filter. If you haven't changed it, you may want to just try putting a new air filter on - that solved our problem of start, but wouldn't stay running.
  • What model? Troubleshooting guide at http://www.flightsystems.com/pdf/onanrvtshootgd608.pdf
    FWIW some ONANS will not continue to run for the following reasons;
    Low oil pressure switch engaged/stuck
    Plugged into shore power will cut off some Onans
    Tripped circuit breaker on Genny
