Here are a few I found in Google under "Motor Rewind Houston, TX." There are plenty more if none of these are close to you. I realize distance in CT is nothing like TX.
http://www.williamselectricworks.com/services.htm
http://hdeei.com/
http://www.manta.com/c/mmfc3hl/adams-electric-motor-shop
http://www.thomasnet.com/southern-texas/motor-rewinding-repair-services-52350808-1.html
I had a rodent problem in my previous MOHO that damaged the rotor. I was doing the repair myself and Onan wanted $1800 just for the part. I found a shop that repaired the damage windings and applied a new (and better) conformal coating for $140. Some shops may not be interested in removing the genset from the rig, so if you are not up for doing that yourself perhaps you can work a deal with your normal service center for just the removal/reinstallation. Good luck.
Lou
05 Travel Supreme Envoy
