tacgle's avatar
tacgle
Onan generator shuts down
I have an Onan Marquis 5500 Generator on my 33R, 2002 Fleetwood Bounder that runs for approximately twenty minutes and then randomly revs up and down, then shuts off. It seems to last a little longer if the motor home is in motion and/or in heat.
I am aware of the ¼ gasoline tank tank automatic shut off and have made sure the tank was full. I have also changed the oil to the recommended higher viscosity of 15W 45, replaced the air filter, removed the oil pressure sensor indicator, and even loosened the gas tank cap, because I had read of vapor locks. None of this has worked. I am not sure if I have a fuel delivery or electronic problem.
The Fault code is 36, which means, “Engine Stopped without Command” (really, it says that!). I have even called Onan and they aren’t sure what it is.
Has anyone else experienced this? Suggestions?
  • On what year models do they have the "prime function" on the gen start switch. Does the rocker switch have like a three step feel, how will you know ?.
    Thanks, Neil
  • Community Alumni's avatar
    Community Alumni
    Thanks, Neil
    On my Onan 5500 (2008), both the in dash and 'on unit' toggle on/off switches have integral primer lights. Hold the switch down and the light comes on indication the pump is priming. I usually prime mine about 10 seconds if it has sat for a month. If I've been using it regularly, it doesn't need priming.
    Personally I'd rather have a choke like on my Honda 2000 I use around the house and the Honda 3500 we use in the race hauler. They don't get too much use (long intervals off) but they sit with Sta-Bil in them and are never an issue. I wish the Onan's would be that way.
  • Packer, your Onan has a choke...it is automatic....the "prime" feature on the rocker switch just activates the fuel pump to ensure fuel in the line and in the carb bowl..well let me rephrase...my 2006, 5500w Onan has a choke and primer feature...I'd bet yours is the same
    Community Alumni
    Mine is the same but what I really would like is a manual mechanical choke; I'm an old school 'hand over the carburetor ' guy ! :B
    ... Eric
