eubank
Jul 15, 2018Explorer
Ours has a similar problem, so I did some youtubing on it. Turns out that the folks I watched seem to believe that the Onans have an issue with evaporating gas turning to varnish in the carburetor, causing uneven running and/or failure to start. One recommendation was to use SeaFoam, as described in the video. (It's a self-serving video produced by SeaFoam about the Onan.)
Ok, carburated motors do have that issue, but perhaps it's something more than the usual. My carburated mowers have always started, as has my trusty MGB, even after months of storage. But perhaps the Onan's carburator is somehow more susceptible to evaporating petrol.
Ours failed to start about a week ago at elevation (7K+). Probably just enough to combine with the messy carburator to cause the issue. Minutes ago -- and now at a few thousand feet lower in elevation (just under 5K) -- it started ok, but runs somewhat rough. As described in SeaFoam's video.
Lynn
Lynn
38,782 PostsLatest Activity: Sep 10, 2026
