rgatijnet1
Jul 18, 2018Explorer III
It is a very common problem for the rubber hose coming in to the generator from your RV fuel tank to have a split that allows air to be sucked in to the carb, which means the generator will crank, but not run long.
Also if you push the switch down it will prime the carb. Then you push the switch up to start.
38,782 PostsLatest Activity: Aug 11, 2021
