Dale_Traveling
Jun 18, 2014Explorer II
Check the ground wire between the generator and the chassis. Same on the other end at the batteries. A poor ground will still give you volts but will limit the available amps. While you are at it also check the hot side.
38,773 PostsLatest Activity: Apr 24, 2026
