cbr46
Jul 27, 2014Explorer
Onan Locked Up
Onan genset (5500 Marquis HGJAB) with 417 hours locket up while running. Got to where I could put a socket on the fan and freed up the motor (working it back & forth) but now when running it sounds l...
cbr46 wrote:
Project is complete. Genny is returned to it's bay and purring like the kitten it is.
6 sheared bolts. That was fun. None of them came out with an extractor, even after days of PB Blaster and heat. They had to be drilled and re-tapped.
Bottom rotor bearing was the main problem with 1/3 of the balls missing, bearing cage chewed up and both bearing covers off. It's a pretty standard 6205 ball bearing. The bearing wouldn't come off the shaft, even with the help of my local NAPA machine shop. I ended up cutting it off with a dremel.
And if anyone needs to replace the fuel filter it's NAPA item 3046 - $4
Happy camper again.
Best,
- c bob
