dufferdj's avatar
dufferdj
Onan QD6000 dies under load
Our Tiffin Breeze (diesel) has an Onan QD6000 that will run for a while (about 1 hour) and then it dies while being used to run the AC. Once to goes dead it takes a relatively long time for it to start back up. I'm trying to get the code to determine the problem, but this morning the generator has run for 2 hours with the AC on and no problems --- but it has not been as hot as when we were having the problems last week. Any suggestions?
  • Check fuel lines all the way back to your tank, you may have a rubber line that is collapsing.
    Ray
  • Have you replaced the fuel filter lately?
    Tiffin used to add one in line with the fuel line that didn’t always get changed.
