azpete
May 04, 2013Explorer
first thing, download a service manual for your system. you cant do a good diagnosis without it. locate the control box, and check all the fuses. if all fuses are good, go to the pump manifold, and check to see if you are getting 12 volts to the solenoid for that jack. if you are, open the valve for that jack and try to run it down. if it goes down, and right back up, the solenoid is is bad.
the service manual can guide you thru the diagnosis. contact me at pfmaddox@att.net. i can help. i work for hwh.
38,778 PostsLatest Activity: Jun 10, 2026
