allbrandauto
May 01, 2014Explorer
you have a electrical problem and its going to be one problem will fix all look at starter big battery wire are any other wires going to that terminal if so take 12 volt test light ground one end and probe other wires for 12 volts if ok go to ign. switch turn ign. on take test light all wires but one will be 12 volts the one that dos not light will go to starter sol. end will light when you turn the key to start if test fails problem is between the to
