Usmcsousa
May 01, 2014Explorer
LVJ58 wrote:
RE: "My Radio has a switch on the dash to Change from the House battery system the to Chassis battery.. Works fine with house batteries"
OK, then your problem is no power from chassis battery, so as others mentioned check connections at battery terminals as well as ground connection to the frame.
Also make sure your chassis battery is good, check with voltmeter and you should get a reading of 12.5vdc +, if lower, replace chassis battery...
Had my battery load tested at Auto zone, resting at 12.8V today. battery connections and Ground are Clean Dry and Tight.
38,781 PostsLatest Activity: Aug 12, 2026
