edzop
May 01, 2014Explorer
Look for a blown fusible link. These would be found attached to the starter solenoid mounted somewhere near the chassis battery, usually within a foot or two. Follow all positive terminal wires and one of them will go to the solenoid. The fusible links, may be several, will be mounted to same terminal as positive feed wire/cable. Good luck.
38,781 PostsLatest Activity: Aug 12, 2026
