tropical36
May 02, 2014Explorer II
edzop wrote:
Look for a blown fusible link. These would be found attached to the starter solenoid mounted somewhere near the chassis battery, usually within a foot or two. Follow all positive terminal wires and one of them will go to the solenoid. The fusible links, may be several, will be mounted to same terminal as positive feed wire/cable. Good luck.
Also check for fusible links in the location of the starter's heat shield, as I think I remember seeing something there when replacing my starter last summer on the road.
I guess not important now that the problem has been mostly solved unless there's somehow a loss to the electrical fan and the dash A/C is on.
