GordonThree
Apr 17, 2019Explorer
dougrainer wrote:
The charge rate feature is NOT new. It has been on Heart/Xantrex and Magnum for over 15 or more years. As explained, ALL it does is allow the Inverter/CHARGER to only pull minimum 120 amps when on less than 50 amp service. IF on 50 amp service there is no reason to change the charge rate. 50 amp service is 100 amp service, not 50 amps total. You determine what your Shore input amp supply is and then set the Charger of the Inverter/Charger to match that incoming amp supply. It then scales back the amount of charge to the Coach Batteries. The higher the charge rate, the MORE amps it will use. Doug
I have the ME-ARC remote like that video, and my Charger menu does not have a "Charge Rate %" setting. I do have the AC-amps setting.
