dougrainer
Apr 18, 2019Nomad
Tom/Barb wrote:dougrainer wrote:
50 amp service is 100 amp service, not 50 amps total.
we are not a direct total service connection.
we are a 200 AMP service to the house, and the RV 50 amp service is taken thru a 50 AMP C/B off the service distribution buss.
our RV service is limited to 50 AMPs.
That's OK. The HIGHER amp draw for the charger is ONLY for when it is on BULK charge. If you leave it plugged in, once it goes OFF BULK charge(usually after 1 to 3 hours), the amp draw for the charger section is negliable. Once in float, it pulls less than 1 to 3 amps depending on the 12 volt load in the RV. Doug
38,782 PostsLatest Activity: Sep 10, 2026
