burlmart
May 17, 2015Explorer
with house disconnect toggled to STORE (OFF), i disconnect house batt's ground wire and read 12.8v between wire and battery ground terminal. is this proper? shouldn't there be no voltage?
edit
with house batt ground terminal off, crank engine, turn house toggle to ON, and engine lights up house things.
wondering if emergency solenoid is sticking, i crank engine toggling ES on dash, and no longer read voltage between house batt grund terminal and ground cable... but, not sure if some BIRD time delay is the cause.
edit
38,780 PostsLatest Activity: Jul 05, 2026
