DaCrema
Nov 10, 2014Explorer
You can be surprised in the VA highlands. A cold front out of the Canada like the one coming this week (Nov 13-16) could yield a surprise dip in temp. Not likely but why worry. In that you will have electric I would fill the fresh water tank and use the on board pump when you need water rather than hook up for fresh water. Generally leave the pump turned off and the water faucets turned on (no pressure in the lines) when you go to bed and run the hot water heater all night. The hot water will help warm the RV (ya I know it is not supper efficient, but like Van Der Waals force every little bit helps) so it is not a wast of propane. Dump the tanks before going to bed and put a half gal in the black and another in the grey. For the grey tank be sure to fill the p-traps in each of the sinks and shower.
38,782 PostsLatest Activity: Aug 31, 2026
