tmaxx's avatar
tmaxx
Opinions on Class C purchase (2003 HR Atlantis)
I am looking at a "new" used RV with more towing capacity. I've found a 2003 Holiday Rambler Atlantis 29PBD with 37k miles for $16,900
. I don't know much about this brand. I haven't looked at the RV yet as is located in another state. I am planning to have some relatives look at it for me on Monday and give their opinion.
I've read some from the Holiday Rambler website and they mention a Alumaframe Superstructure which includes aluminum siding and roof. This is the first I had heard about aluminum being used on the exterior of a modern RV. Are there advantages/disadvantages to the aluminum in terms of water leakage?
I could use others feedback on the quality of the Holiday Rambler Atlantis class c RV.
Are there any weak areas with this brand I should focus on when checking out this RV?
The dealer selling this mentioned that the auxiliary battery needs to be replaced. I am not sure what this battery is used for. Would it be something I would need to replace before driving to my home?
  • I'd definitely get the dealer to throw in the house batteries. I believe HR uses fiberglass roofs, which is better than sheet rubber. Seems like aluminum would be better than wood. One less thing to rot. Does this unit have smooth aluminum siding (as opposed to fiberglass)?
  • You do need a working auxiliary battery. There are a few things that work off of that. Most refrig need it to start up, all lights when not connected to electricity, the furnace at all times. Wether you need on the way home is up to you, but I think the seller should replace it so that you can fully check out the camper. For instance, does the furnace work, or refrig. If there is a slideout, that may or may not need the battery.
    I would suggest you hire a RV mechanic to check the unit out if you decide to buy it. From you question, I take it that you are a newby to RVs.
