C-Leigh_Racing
Jan 20, 2014Explorer
Merry,
When you folks go back & check on the coach your thinking about, get someone to crawl under & see if the chassis has the rear trac bar added to the rear axle.
If it does not, that is one item that needs to be added to make the handling of the coach better, get rid of the tail wag a long coach will have.
If it does not have the trac bar, I would not use that as a deal breaker, because the F53 is a good chassis.
Neil
Neil
38,780 PostsLatest Activity: Aug 05, 2026
