bsinmich
Feb 19, 2014Explorer
Being stored in a garage helps a lot. Assuming there are no leaks, the first thing I would do is Eternabond around the roof where it meets the sidewalls, on any seam on the roof and the end caps, and use Dicor to seal all the remaining roof protrusions. The last thing you want in any MH is a water leak and prevention is a lot cheaper than the cure.
For you and also Angel3 you should flush the brake fluid on a regular basis every 2-3 years. Brake fluid absorbs moisture and that is what causes brake calipers to hang up. Lubing the caliper sliders can also help from hanging calipers.
38,781 PostsLatest Activity: Aug 12, 2026
