DaHose
Feb 20, 2014Explorer
You might be under-rated based on your OEM springs. If so, you can get around the CCC issue by confirming the capacity of your rear axle and then adding airbags to achieve that maximum capacity.
At 31' long you might also need to reinforce the frame extensions connecting to the rear hitch, if that hasn't already been done.
Jose
Jose
38,781 PostsLatest Activity: Aug 12, 2026
